Ana içeriğe geç
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
396 Soru Tümünü görüntüle
brightness drops to 75% randomly
hello, i have replaced iPhones xs screen bought from ifixit (the OLED Packeg) replacement smooth and fine but i've noticed that time to time brightness off the display drops to around 75% (the top 25% won't do anything) and stays like that, seems pretty low and some time hard to see under sunny environments, reboot won't fix the issue but after sometime it fixes it self, is this a know issue? (BTW this 2nd screen replacement of the device first was done by Thirdparty and was working fine in these regales but had other issue which to me was a bad panel used by the shop even had bad fitting issues) this panel does not have such issue 3D touch is working fine too which wasn't working before. any idea what is causing this behaviour? BTW auto brightness works fine when this issue is not present.
Bu iyi bir soru mu?
Puan 0
3 Yorum
How hot is the phone?
tarafından
not hot normal temperature @areeve
tarafından
that is what causing but phone is not overheating is slightly worm it use to get even hotter before and never had this issue even is display replaced.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Screen dimming is part of the overheat protection, it is overheating or at least it thinks it is.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
i will do the test again to make sure if this is causing, then after it turns to normal temperature it should go back to normal isn't it? then why doesn't it go back to normal?
tarafından
@rokieride It doesn't think it has returned to normal temperature.
tarafından
Yorum Ekle
Yanıtını ekle
Rokie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 68
