flashes Fdl with door open
I just replaced the waterpump,and was testing the washer. When I plugged the washer into a 110 outlet, it flashed FDL. Does this mean I need to replace the lokcing mechanism?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
M Crowell, the error F/dL can be caused by:
"A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure" from the manual.
check all those things out, and you may have to replace the mechanism. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 436
