Where is the airport card located
My macbook took a hard fall and screen got damaged, also when i connect it to a monitor, it says the there is no blue tooth or WiFi hardware. I’m guessing the airport card got damaged to. However, I can’t seem to find the location of the airport card ? The model of my MacBook Pro is A1706.
Update (06/19/2022)
can you point out where the components are?.......................
Bu iyi bir soru mu?
4 Yorum
[image|2682120]
Vic X tarafından
Correct me if I’m wrong but don’t the MacBooks have their antennas as part of the display assembly
I know that was the case with the pre2016 ones
But once again correct me if I’m wrong:-)
HelloMacOS tarafından
@hellomacos so the antennas need replacement?
Vic X tarafından
I would say so yes!
It seems wrong to say that it’s the WiFi chips as if the fall was the culprit I’m surprised that it didn’t damage any other parts of the logic board as Iv seen bent boards that still retain full functionality
The only thing is that the WiFi antennas are embedded under where it say “MacBook Pro “ on the chin of the display
I would try unplugging the connectors for the WiFi and pugging them back in as after a fall it can dislocated some connectors and cause them to act strange :-)
