Ana içeriğe geç
Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
242 Soru Tümünü görüntüle
Why my MacBook Pro keeps going into a black screen while I am using it
MacBook has been working perfect, but lately it is going into a black screen while I am using it....it does not go into sleep mode.....I can see still up and running but the screen just decide to go black. Usually if I close the lid and wait about 5 min....when I open it up...the screen will come back on......but after a few minutes back to the same thing. been trying different things...still no luck
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Comments:
What do you see when you press a flashlight against the display? Do you see the faint image of your desktop and its icons?
tarafından
Nothing.....but I can still see the webpages on the Touch Bar.....it just happened....closed the lid.....waited a couple of minutes...open the lid and back and its back on
tarafından
Well, now you've confused me! So the issue is the TouchBar not the main display?
Let's start again as we have incomplete and confusing symptoms. Which display is going black? The main big one or the Touch Bar?
When you put the system to sleep by closing the lid does the keyboard light up as you lift the lid? What happened when you press on the keys or touchpad does the system react?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
This is a known issue with the 13" 2016 models; Apple even has a quality program that covers it.
https://support.apple.com/13-inch-macboo...
Although it doesn't cover the 15" models, I've seen the same thing happening on a number of them.
Short version, you need a new display; part number 661-06375 for Space Gray, 661-06376 for Silver. If your display has no signs of physical damage it'll cost you $530; with damage it's $620. If you call Apple and play the right song for them, they MAY give you a CS code to get the screen replaced for free. They've been known to do stuff like that ("surprise and delight"). Good luck.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Comments:
@steve_g - If you noted the test I recommended "What do you see when you press a flashlight against the display? Do you see the faint image of your desktop and its icons?"
Macmod did not clarify what the problem is so its best not to throwout conjecture!
tarafından
@danj It's not conjecture.
tarafından
@steve_g - You are assuming this is a FlexGate issue, but with no clear data you can't be sure! The OP could have an issue with the TouchBar the way it is written. If we had gotten clarity then I could see this as a possibility.
Besides the FlexGate repair program has ended for the 2016 systems! Vintage and obsolete products listing
tarafından
Yorum Ekle
Sound to Me like a Logic Board and Backlight problem,
I can't seem to find the schematics for the Logic board though,
I've found some schematics
Puan 0
Yorum Ekle
Yanıtını ekle
Macmod sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 46
