Ana içeriğe geç
Both sides are either too cold or too warm
First noticed freezer had defrosted. Food was defrosted and water was everywhere. Then noticed fridge side was also too warm. We cleaned coils. We adjusted dials to coldest on both sides. Both sides became too cold. Food in fridge froze. We did the reset of turning dial to off and back on. Several times over the course of time. Each time we adjusted the controls to a moderate setting, both sides became too warm. Each time we adjusted dial to maximum cold, both sides become too cold. We adjusted in small increments with the same extreme cold or warm result. What can cause this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
Hi @ticagrumpy,
What is the model number of the refrigerator?
tarafından
ED5FTGXKT02 is the model number
tarafından
We removed cover from back of freezer and did not see ice.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @ticagrumpy
If there was no ice on the evaporator unit then given the symptoms that you describe the problem may be with the thermostat assembly.
The supplier link is an example only to show the part and how to replace it etc. Search online for WP2198202 to find suppliers that may suit you better.
Regulates the temperature inside your refrigerator to ensure it remains at the desired level. Görseli
Ürün
Whirlpool Sxs Refrigerator Thermostat - WP2198202
$76.99
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you! Everything I’ve tried and learned via videos supports your suggestion.
I appreciate your help very much.
tarafından
Yorum Ekle
try to find out what is causing it in the first place, then buy a for parts fridge that looks like yours and replace the "heaters" of the side of the fridge it will look like a pipe shaft like the sewers after replacing the pipes" make sure the comecters that heat up the pipes dosent get damaged or you willl have to redo the painfull process
Puan 0
Yorum Ekle
Yanıtını ekle
Elizabeth Jones sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 282
