Ana içeriğe geç
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
199 Soru Tümünü görüntüle
Do I need metal graphic for iMovie
Hi everyone,
I have Mac Pro 3,1 and I install macOS Monterey (patched), everything look OK (except BT - but I know about hits issue) but when I try run iMovie it's crashing :( I know that I need Metal graphic card for Final Cut Pro, Motion 5 and Compressor 4 but do I need it for iMovie as well ? Currently I have only HD4870.
Thanks a lot for your time guys.
Bu iyi bir soru mu?
Puan 1
19 Yorum
@roboscrap
What version of iMovie are you trying to run?
I believe different versions need different specs:-)
tarafından
last version in macOS Monterey
tarafından
@roboscrap
I don’t think you need a metal graphics card for iMovie as one of my friends has a non metal MacBook Pro and it runs iMovie just fine
Can you tell me the specs of your machine so I can get a better idea of where the issue may be:-)
tarafından
It's old Mac Pro 3,1 :)
tarafından
@roboscrap
What cpu and ram?
You can find this information by clicking on the apple logo and then clicking on about this mac
tarafından
14 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You'll need to get the older version of iMovie as the newer version does require a GPU that offers Metal API support.
Looking for iMovie Old Versions? Here are the Downloads
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
Thanks a lot, I was confused as I can't find if iMovie need Metal GPU or not :)
tarafından
@roboscrap - Apple rarely tells us much as they always assume you have the current models not Vintage and obsolete systems.
So when you are force fitting a newer OS than what Apple had qualified for the given system you do need to stick with the older OS supplied apps if you are dependent on them. Or at least use an external drive to test the new OS and/or apps to make sure you don't go to far!
Some upgrades can't be rolled back so it's also important to setup a good backup strategy. As an example I was using a backup rotation with four sets of drives rolling them every month pre COVID, now with very little business I'm doing it every three months with a set in a safety deposit box just incase of fire or flood.
But I'm very dependent on my work so it would be a great loss. My practice may be too extreme for you.
tarafından
@danj I have one SSD with last supported macOS ( El Capitan) and one SSD where I am playing with not supported macOS etc… the good thing is that I have all important things on other HDD ( this is why I love MacPro) so just switching SSD - I never using both SSD inside - just in case. And also have backup on cloud and external SSD. But thanks for advice.
tarafından
@danj
I was just looking on iMovie issue and find that macOS High Sierra have iMovie 10.1.6 or iMovie 10.1.9 but I have macOS High Sierra with installed 10.1.12 (10.1.12 is from macOS Mojave) and it's running without issues -> so again I am confused :D
tarafından
@roboscrap - You're getting your self confused!
What was shipped within the OS installer is not what was the highest a given macOS has for iMovie. Apple does maintenance and feature updates within the given OS's support window.
So if you where to scratch the drive and lets say install Mojave afresh then you would have installed 10.1.12 and then during its run you would have installed OS & Security updates and there would often be a update for the apps as well.
So as an example I have Mojave on this system and the version of iMovie is 10.1.14 so its' had at least two updates from the release of Mojave.
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Rob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 509
