Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
red light flashing after refill thermal paste
i have fixed my ps3 having had a ylod when i switched it back on it goes from a green light to a red flashing light the yellow light is gone.What could be the problem has anyone had the same problem. What did i do wrong.
Bu iyi bir soru mu?
Puan -1
1 Yorum
How did u solve this problem ?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This suggests a temperature issue. recheck that you have assembled the system correctly and the heat-sink is making proper contact. Too much paste is as bad as not enough. Check out THIS guide for some good general advice on applying thermal paste.
Could also be a fan issue - unplugged, jammed, dirty etc.
To test the fan, turn power OFF, hold the eject button.
While holding the eject button, press and HOLD the power button till the power light is green. When you release the button the system should beep
The fan should run at FULL speed and eject any disc that is inside.
the fan should run for around 15 seconds and then stop.The ps3 should then beep 3x and flash a red light.
Power OFF and then power up normally to reset to normal mode after fan test.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
thibautcordiez sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 7,179
