Ana içeriğe geç
Repair and disassembly guides for microwave ovens.
714 Soru Tümünü görüntüle
Slower heating after outside venting conversation
I recently changed the vent from recirculating to venting outside. It is now heating slower. What could do this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Is this a major modification? If this is an air cooker, recirculating heated air is the main concept of using the same heated air to increase temperatures for highest efficiency. Venting air cookers simply won't allow heat to build up.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The difference is the position of the fan and the vent. The vent contains a damper that opens with the air pressure. I have installed these and found I did not position things properly and the damper never opens.
These vent are not part of the heating process, they just exhaust cooking fumes from the range below. However, if trapped, they may circulate in the oven and lower the temp of the food.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
That was exactly what it was. I pinched the damper housing on install. Got the damper moving again and it went back to heating normally. Thank you for the help.
tarafından
Yorum Ekle
Yanıtını ekle
Hank Brackett sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 20
