My laptop is acting funny.
I need help. My laptop sometimes acts weird like, I can't click anything but my mouse still working and able to move on screen. It usually happens when I'm switching tabs between software. my laptop sometimes also suddenly mouseclicking and scrollclick on itself. I've updated windows/GPU and drives but still happening. need help
Bu iyi bir soru mu?
5 Yorum
I also have the same issues. My laptop don't work at all for a while. But after that, it works well. What should I do to recover this issues?
Larry Murray tarafından
@larrymurray
If your having the same touchpad issues as the OP above, try the answer below to determine if it is the touchpad or something else.
jayeff tarafından
@jayeff Yeah, touchpad. I'm a little bit confused. Should I need to replace my laptop touchpad?
@larrymurray
Did you try what was suggested in the Most Helpful Answer below?
If disabling the touchpad and using a USB mouse stopped the problem from happening, it looks like there is a problem with the touchpad.
jayeff tarafından
Yes, I figured it out later. My touchpad didn't work.
