How do I replace airport card in mac pro intel?
How do I replace my WIFI card in the Mac Pro intel desktop??
Thanks for your time
Update
serial .G88421KWXYL
Thanks for the info in advance also.
Bu iyi bir soru mu?
serial .G88421KWXYL
Bu iyi bir soru mu?
It's located right on top of your logic board and you just take the screws out and snap a new on in like RAM. For the correct procedure and part please give us the last three figures of your serial number.
Bu yanıt yardımcı oldu mu?
Apple Mac Pro "Eight Core" 2.8 (2008) Specs
Identifiers: Mac Pro Early 2008 - MA970LL/A - MacPro3,1 - A1186 - 2180
Remove the two screws holding it in place. Snap off the antennae connector, pull it straight off the board (it's in a socket connector). Do you need the part number?
No thanks Mayer, I got the part already.
Thanks for your help
Also, here are some images that might help you out. The main trick is dealing w/the connectors. I had to hold the card in my right hand at an angle and with thumb above and index finger above the card snap them in place. Also, the card I bought didn't come w/screws (Apple brand) which is weird. Make sure you use cable 1 & 2 and connect them to the 1 & 2 on the card. It is pretty hard to find, but it is there.
Note location of card after installation
close up of card - before insertion
close up of card - once connectors are on card and in place
close up of card - after insertion
Jamil
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,109
