Ana içeriğe geç
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
546 Soru Tümünü görüntüle
Black color doesn't work + burn-ins and flickering
My 2017 Macbook Pro can't show the color black on the screen. Whenever the color black appears on the screen, it turns green and flickers. Apart from this when i have something black on the screen for too long, it burns in to the display. And finally when I'm starting the computer, 6 dark lines are seen on the white apple logo screen.
On the right side of the display, you can see how it looks. And on the left side, I'm using the screenshot tool (which makes the display lighter).
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
What does an external display look like via the mDP/Thunderbolt connected display?
If the image is clean on the external then you know the issue is localized within the internal displays T-CON logic which is the small logic board thats is attached with the coming for the display assembly.
If the image also shows the same defects the MUX logic and/or the CPU's graphics logic needs repairs.
Bu yanıt yardımcı oldu mu?
Puan 0
4 Yorum:
It worked fine without problems on an external display.
tarafından
tarafından
So, just as a small follow-up question; do you think i should buy another one? Or should I replace the display on the one I have?
tarafından
@oryberg - Replacing the display assembly would be the cheaper direction. Does the system serve your needs now if the display was working properly? If not then maybe it's time to invest in a new system, but that's a big outlay.
tarafından
Yorum Ekle
Yanıtını ekle
Oscar Ryberg sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 31
