Ana içeriğe geç
Apple's fifth-generation smartwatch, with optional cellular connectivity, released September 20, 2019.
Screen & battery not working.
I purchased battery, screen, & touch gasket from Ifixit. I followed the tutorials to change the battery, but I broke the original screen. Watch continued to work fine with the cracked screen, but I decided to replace the screen and gasket. After 1st attempt I had black screen but haptics worked. After trying to fix the black screen, I now have no screen, no haptics, & no response from a reset or charging. Any ideas? I just ordered new flex cables to see if that’s a fix. I also noticed the center connector on the screen moves a little when I try to plug in the cable.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
You maybe digging a deeper hole here ;-{
The cable assembly requires desoldering from the SIP package! Do you have a Hot Air rework station?
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
I do know how to solder and desolder, so hopefully it’s still possible. I can’t figure out why the haptics stopped working tho!
tarafından
@amberds - You have access to a Hot Air rework station as that is what you need a simple pencil soldering iron won't work here.
This is getting worse if haptic engine is damaged too ;-{
tarafından
I actually think something is going on with the battery. The cables don’t have any bends, tears, or bare spots, and they plug into the screen easily. The screen is brand new. I guess we’ll see.
tarafından
Yorum Ekle
Yanıtını ekle
Amber sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 19
Her zaman: 138
