Irobot brava can't unlock buttons after wifi pw reset
Changed home wifi PW but the buttons on Brava m6 were pet locked. I can't get back into the my to unlock buttons. Need to press to buttons to reconnect to new wifi.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This worked :To turn Child & Pet Lock off without the app, tilt the robot so that one wheel is pressed into the ground (the wheel springs are fully compressed) and the other is floating in the air (the wheel springs are extended, not compressed). While holding the robot in this tilted position, press the CLEAN button 3 times. You will hear a sound and the light ring will illuminate white for 3 seconds to confirm.
You will be able to hear a chime sound once you have disabled Child & Pet Lock with the appropriate button combination.
Bu yanıt yardımcı oldu mu?
Once you hear the chime, hit clean button one more time
Awesome tip!!!! You solved my problem!
The iRobot rep didn't know this trick for the M6 Braava. He said that trick was solely for the J series robots. He thanked me for the new info. Thank you for the tip.
It really works! You just have to tilt it on an angle high enough. It works! Thank you 🙏
Excelente ♥️
Tengo una roomba i3 con conexion wifi, la configuré con la app con bloqueo para mascotas/niños, pero ¿qué pasa si pierdes el móvil o como a mi, te cambian el router y la configuración wifi es nueva????. pues que la roomba se queda bloqueadda ya que no puedes pulsar los botones para conectar el bluetooh y que te la detecte el movil, suena un odioso mensaje "los botones están bloqueados use la app para limpiar"
Correo a soporte y la solución en spanish:
En primer lugar, para desbloquear los botones, siga estos pasos:
Teniendo el robot fuera de su base de carga, incline el robot de modo que la rueda derecha quede presionada contra el suelo (los muelles de las ruedas están totalmente comprimidos) y la otra flotando en el aire (los muelles de las ruedas están extendidos, no comprimidos).
Mientras sostiene el robot en esta posición inclinada, presione el botón CLEAN 3 veces. Escuchará un sonido y el anillo de luz se iluminará en blanco durante 3 segundos para confirmar.
Al conseguir desbloquear el robot, acceda en su aplicación móvil - Configuraciones del robot - Configuraciones Wifi - Cambiar wifi del robot y siga los pasos para vincularlo con el nuevo router.
While holding the robot in this tilted position, press the button 3 times:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 92
Her zaman: 5,280
2 Yorum
I have the same problem... Have you find any way to fix it?
Mikael Longpre tarafından
Unfortunately not yet
M Rezzag tarafından
