iPhone 11 Pro Screen Removal
If you don't have a hot plate for screen removal, could a glass cooktop on low heat be a viable substitute? Or would that just destroy things?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
In my experience, heat is not necessary, but can be helpful on these displays. A suction cup and some force is generally sufficient.
As was previously mentioned the iOpener tool would fit the bill, but if that’s not an option, I have been known to use “heating pad” type alternatives. Rice, barley or oats in an old cotton sock + a microwave would serve a similar purpose. Although these contain some moisture, so I advise caution when employing this method. Or encasing in shrink wrap or a ziplock bag before applying to the phone.
Bu yanıt yardımcı oldu mu?
Hi Tony,
I'm not clear on why you feel you need a hot plate for removing the screen, but I'd be leery of using a cooktop, especially when a hair dryer will work suitably instead. The iFixit iOpener is pretty inexpensive and will do the job, as will a hot air gun if you have one. Here in the US, you can pick one up at Harbor Freight for about $17, but you do have to be a bit careful with it, as you can overheat an LCD or OLED display with them and ruin them that way.
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 16
Her zaman: 16
