Ana içeriğe geç
Mart 2015'te duyurulan ve 10 Nisan 2015'te piyasaya sürülen Galaxy S6 Edge, Samsung'un en yeni amiral gemisi akıllı telefonunun kavisli ekranlı versiyonudur.
Why won't my phone turn on?
I don't know what happened it was working a few minutes ago until suddenly it started going a little glitch then I tried to turn it off and it worked so I wanted to turn it on again but it isn't working im charging it right now and I don't know what to do I need this fixed in 3 days.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Y.I.N.E try a power cycle first "There are multiple ways to reset your device if you are experiencing issues. The first step is to power cycle your device. Press and hold the Power/Lock button, then select Power off. Select Power off to confirm. To turn the device back on, press and hold the Power/Lock button until the screen lights up.
Note: If you are unable to power your device off or if it becomes unresponsive, press and hold the Power/Lock button for 10 seconds, until it reboots." If that does not work check through other solutions for a software issue on here If none of those work, you have to dig a lot deeper into the bowels of your phone ;-) Follow this flow sheet to narrow it down. the images are best viewed when downloaded and using your own image viewer.
Resim
Resim
Resim
Resim
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Thank you for your help but I realized that my phone is just dead since it is a old model and the battery has been steadily declining.
tarafından
@Y.I.N .E just replace the battery and start from there. "just dead" should be an easy fix ;-)
tarafından
Yorum Ekle
Yanıtını ekle
Y.I.N .E sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 924
