Ana içeriğe geç
The Surface Laptop 2 by Microsoft was released October 2018.
18 Soru Tümünü görüntüle
New battery fitted .. charges and visible but won't operate on battery
Hi
Microsoft surface 2 Laptop battery replaced successfully. It is recognised and charges to 100% but as soon as I disconnect the power supply it shuts down. Have tried software fixes but I belive it is hardware.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum
Hi there
I replaced with the same make from Microsoft (https://www.laptop-battery.org.uk/laptop...) and with the right connector.
I checked both batteriers with a DC voltage meter and the original was 7.5v but the new one was 8.5v. Should that make a difference ?
Thanks
tarafından
Craig Smyth always double check your work to make sure nothing got missed. Check the connector and check the pins. Make sure there is no damage.
tarafından
Hi there
Thanks for the answer. I checked and double checked it. I was very careful and there was no damage and the pins were fine.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi craig,
The issue occurs mainly due to compatible battery. Did you replaced the original one with different make(compatible).
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Hi there
I replaced with the same make from Microsoft and with the right connector.
I checked both batteries with a DC voltage meter and the original was 7.5v but the new one was 8.5v. Should that make a difference ?
Thanks
tarafından
Yes power (Voltage & current) makes difference have faced similar issues in the past but not with surface book
tarafından
@ds17 I have asked the supplier to send me a new battery and will try when it arrives. It is defintely the right part number and product ordered and is a microsoft battery so I was surprised the voltage is higher than specified even as written on the battery
tarafından
Craig
The issue is with the power sensing unit if i'm right In most cases if the power output either above or below the sensing unit gives feedback as compatible. Have a word with supplier they might propose something new
tarafından
Yorum Ekle
Yanıtını ekle
Craig Smyth sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 511
