Stuck on High RPMs
I recently cleaned my 2008 Chevrolet Silverado 1500 4x4 throttle body and now it's stuck on high RPMs any solution to how I could fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Its either a Vacuum Leak, Bad Fuse, or a Faulty Air Control Valve
I see the Air Control Valve being the culprit on older cars because of high carbon buildup over time, giving you an P0505 Error Code. Speaking of error codes, did you use a Scan tool on the truck? If so, could you post the results here?
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 129
