Ana içeriğe geç
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1098 Soru Tümünü görüntüle
Why is my replacement battery charging slow and dies completely at 60%
Hello, I recently bought a iFixit battery for my retina 2015 MBP. After installing it I did the calibration steps the guide tells me to do. I charged it to 100% and kept it plugged in for 2hrs. When I unplugged it it was going well dropping very slowly. After 2hrs 27m, it shut off and when I plugged it in and turned on my mac, it was at 1%. After letting it charge at around 46% it was stuck there for like hours. I did a SMC reset and PRAM reset, but nothing worked. After letting it sit plugged in I unplugged and replugged in my adapter and after a few minutes it jumped to 100%.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Comments
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adding images to an existing question
tarafından
@danj I added it to the post.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
mmm ... Something is very odd here!
Note the two manufacturing dates are both 2015! So SMC still thinks you have the original battery installed. So you need to do a full SMC reset to clear this only info as the new battery won't work correctly until then. Shut down your system unplug the battery and anything plugged in the external ports press and hold the power button for a good 15 secs to fully discharge the logic board. Now plug in the MagSafe charger the system should spontaneously boot up, did it? Let it fulled boot and do a proper shutdown. reconnect the battery and restart again, let the system sit for a good 5 minutes and take a fresh snapshot post it here while its still plugged in.
Bu yanıt yardımcı oldu mu?
Puan 1
6 Comments:
Battery date is after machine date. it should be before, so it's not the original battery.
tarafından
@mayer - I noted that as well, I suspect during Apple Q/C it was switched out. The dates are so close I don't think its 3rd party.
tarafından
I did a SMC reset and the battery still says it was manufactured in 2015.
tarafından
@tjk152 - contact the iFixit store for a replacement battery. Make sure you point to this question.
iFixit Customer Support
tarafından
@danj I emailed them and they agreed to send me a replacement battery.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
TJK152 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 50
