Can I swap a MBP 15" SSD using a MBP 13" SSD? Both early 2015
What the question says. My 15" SSD is failing, and was wondering if a 13" SSD would work on it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
If they are both 2015 models, then yes they are inter compatible. Earlier years may also work, but don’t always support the same speeds, even if they fit into the same slot.
Bu yanıt yardımcı oldu mu?
They are compatible with each other so yes it will work.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 41
1 Yorum
@erjaw Becareful! Not all of the blade SSD's are interchangeable!
There is both a few different interfaces and size difference between some of these so review this guide to see what will work The Ultimate Guide to Apple’s Proprietary SSDs
Dan tarafından
