Ana içeriğe geç
Replacing iPhone earpiece speaker; lost a Phillips screw. Will it work
I was replacing my iPhone 11 earpiece speaker and I lost a Phillips screw that holds the assembly inside the phone. Will the speaker still work or will it have issues if only 1 screw is missing from the assembly?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
I think it will work fine as the speaker has separate connections and doesn’t use the screws for anything apart from holding itself to screen
I would replace it if given the chance though but it should work without it
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
It will most likely work, but if you are worried about it you could try to find a replacement screw. You can buy the sets of all the screws on eBay and a bunch of other places. Also make sure you replace the water proof seal when you finish the repair.
Puan 1
Yorum Ekle
Yanıtını ekle
Juan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 266
