Ana içeriğe geç
The Early 2009 Mac Pro—also known as the Mac Pro 4,1—introduced Intel's Nehalem architecture to Apple's line of professional desktop computers in March 2009. The Mac Pro 5,1 used the same interior design but received further CPU updates in 2010 and 2012.
201 Soru Tümünü görüntüle
Will be this RAM compatible?
Hi guys,
will this RAM work in Mac Pro 5.1 ? Currently CPU support only 1066MHz but will be updated to X5690 and this CPU support 1333MHz.
https://www.amazon.com/Samsung-M393B2G70...
or
https://www.memory4less.com/hynix-16gb-d...
Anyone have it ?
Thanks a lot.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Give this a view Upgrading my Mac Pro to the MAX CPU and RAM
Bu yanıt yardımcı oldu mu?
Puan 1
10 Yorum:
Thanks for the video. But my main concern is that these RAM’s are 1600MHz and MP with top CPU can do only 1333MHz.
tarafından
@roboscrap - Watch the vid again as he explains which can support the higher speed RAM.
tarafından
@danj I am wondering if anyone have experiences with exactly these types of RAM’s as they are 1600MHz and I don’t know if they can run on 1333MHz. And he talking about 1066 and 1333MHz.
tarafından
@roboscrap - You are limited by two factors: The given chipset the logic board offers and what the CPU can support. The maximum speed RAM is either 1066 or 1333MHz depending on the logic board. While it might be possible to install 1333MHz it won't run any faster than what the logic board supports.
tarafından
@danj so if I use 1600 even 1866MHz it will RUN, but only on 1066 or 1333MHz depend on CPU (logic board can do 1333MHz)? Because I know that some RAM’s can’t “slow down” - had this issue with PC, but I am new to Mac Pro world. That why I am asking.
tarafından
5 tane daha yorum göster
Yorum Ekle
So I ordered 8x Samsung 16GB DDR3 ECC 1600MHz (details below!) and it's working for now :) running at 1066MHz. So this memory stick's are compatible with MP 5.1 (if you have dual CPU you can go up to 128GB).
Will let you know if I will have any issues in future :)
Puan 0
Yorum Ekle
Yanıtını ekle
Rob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 157
