Power up and shuts off on it's own
I power my tv on (Sanyo DP50747 Plasma) and the picture acts like it wants to come on, then shuts off within 10 seconds. I power it up again and the screen shows a little more. When I do it a third time it acts like it is warmed up and works fine after that. I took the back off and looked at the fuses however they have a white film over them. How do I fix this? It has to be something simple.
Bu iyi bir soru mu?
2 Yorum
I have a Sanyo flat screen and I power it on and it takes like 5 to 10 seconds and then shuts itself off second time I turn it on it comes on for like 5 Seconds and then the third time I turn it on comes on shuts off and won't power back on any help
Thanks
Brandon Schober tarafından
I recently had this issue and was able to find the same tv with a damaged screen that I could use for parts. After swapping the power boards. I still experienced the same issue. I then unplugged the board that controls the power button on the side of the tv and the problem went away. I then swapped the boards from the spare tv and all is working fine.
Jon Boyd tarafından
