Ana içeriğe geç
Buick Century'nin son nesli, 1997 model yılı için 1996'nın sonlarında piyasaya sürüldü.
Why won't the check engine light go off
I have a 2001 Buick park avenue and the check engine light refuses to go off no matter what I do sometimes it goes off until I turn the car off and back on then it comes back on I need to get it emissioned but can't with the check engine light on PLEASE HELP
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mysamsung0 you will have to get the OBD scanned to determine what is creating the error. Until you do that and fix whatever needs to be fixing, it will not turn off.
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Hi Wendy, I agree; there's a problem with your car that the check engine light is trying to tell you about, but you do need a scanner to be able to read that information from the car. All cars made since 1996 have a connector built into them that you plug a scanner into.
The good news here is that most auto parts stores will bring their own scanner out to your car and scan the codes for free.
So if you can do that then come back and add the codes to your question, I'm sure we can help.
tarafından
Have already done all that I even went and bought my own machine
tarafından
@mysamsung0 that is awesome. Did it give you any codes? which ones?
tarafından
Yorum Ekle
Hi Wendy,
My dad, a former Buick dealership mechanic taught me this neat little trick to reset your electrical system. It has fixed many little issues, and should turn off the check engine light. Unless, of course, there is something that is causing a code to come up, in which case, check your engine.
Try this.
1) From engine off position turn the key so the full battery comes on (stereo should come on, but don't start the car).
2) Floor the gas pedal 5 times, all the way down, quickly.
3) Turn key to off position.
4) Start the car right away.
Hope this helps!
Puan 0
Yorum Ekle
Hi wendy id say first and foremost its gonna be your Catalytic converter it'sprobably clogged up needs To be replaced if this is the case your check engine light won't go off until replaced and the system resest. Any average garage can fix this.
Puan 0
1 Yorum:
No, absolutely not, do not replace your catalytic converter.
There are hundreds of reasons why your check engine light could be on, and a catalytic converter is only one of the possibilities. At this point there's no reason whatsoever to think your catalytic converter is bad, at least not until you have your engine codes and can analyze what they mean.
tarafından
Yorum Ekle
Yanıtını ekle
Wendy King sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 827
