Ana içeriğe geç
Whirlpool french door WRX735SDHZ refrigerator not dispensing ice/water
Our french door fridge only dispenses ice and water if we slam, jiggle, pull the door out slightly until it engages. It is not consistent either. Sometimes we can hold it just right and sometimes it just won't work. Is this an issue with the trigger or do we need to adjust the door? I am at a loss. Anyone else experience this and have a fix?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum
I have a Whirlpool MFI2569VEA French Door Refrigerator with the same issue. To get the Ice and water dispenser to operate, I need to repeatedly push the door switch. Both switches are new and test fine. Has anyone found a solution? I don't want to invest $200 in a control board, It does not seem to be a board issue, Any Suggestions?
tarafından
@scott2016
What is the full model number of the refrigerator as there are three different models having different specs -EA1, -EA2 and -EA10?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
With the freezer door open, manually operate/release the freezer door switch and check if the light turns off and on.
If the light only intermittently works correctly it may be a faulty door switch. (part #W11396033).
The dispensing action only works when the door is closed and the only way the control board knows this is because of the door switch being operated.
Activates the interior refrigerator light when the door is opened. Görseli
Ürün
Whirlpool Door Switch - W11396033
$27.99
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
outofgravity70 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 849
