Ana içeriğe geç
Repair and disassembly information for the 2020 refresh of the MacBook Air model A2179 with an Intel processor that was released in March 2020.
74 Soru Tümünü görüntüle
Can't charge my MacBook
So i spilled some water on the left side of my laptop, unfortunately when I try to charge it there is no power, but everything else is fine the speaker, lcd,etc works just fine. What should I do please help thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Sistria Nova, First thing to do is to stop trying to charge and use it! Trying to charge and further use it, only increases the speed of which the corrosion starts.
You’ll have to open the Mac up to get access to the boards inside. You can use this guide to get a sense of how to get inside. Note that there are incredibly delicate parts, so you’ll need to be very careful! The first thing to disconnect is the battery. You’ll have to take it completely apart, logic board and all boards out. Once the boards are out, you should use some distilled water to clean off the boards with a soft brush (preferably ESD safe, but a toothbrush will do). Do not use tap water, because of impurities.
Once all the boards are cleaned, use some >99% isopropyl alcohol to go over the boards again. IPA displaces the water and dries off many times faster than the water. Use the brush again, but remember to be very careful! Tiny and delicate components don’t react well to force.
Let the boards dry off for a few minutes, then inspect them using a magnifying glass for any damage or corrosion you’ve missed. If everything checks out reassemble the machine and test it out.
Hopefully it will have been caught in time, if not post some good quality and up close pictures, and we’ll see what we can do :)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Sistria Nova sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 12
