Ana içeriğe geç
Repair and disassembly information for the Samsung Galaxy S21 5G Android smartphone, announced and released in January 2021.
46 Soru Tümünü görüntüle
s21 5g wifi problem
Hello everyone
i got a new motherboard for my s21 5G
after I installed it I noticed that bluetooth is not working correctly ( turning off on its own)
so I opened the phone again and I noticed that I made a big mistake since I placed the mob under the side of the camera and almost bent the board.
Anyway after correcting Bluetooth is now flawless but now every time I do something that causes a small amount of heat like gaming or youtube short for 30 cause wifi to turn off if the phone is too hot wifi will refuse to turn on until it cools down.
am not sure where the wifi IC on this board could anyone help me?
G991U
the board was replaced because it was locked.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@coliotte any change over the last 6 month or still the same issue? Is this " where the wifi IC" still the main concern. Can you post some GOOD pictures of your motherboard ( front and back) with your QUESTION? Adding images to an existing question
Does your phone give you any kind of error message that it is to hot etc? It might be an issues with a thermal sensor that cut off your Wifi. Your phone has no issue with Bluetooth during that time?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You damaged the board by not fitting it correctly. Some solder joints have cracked and when the board heats up they separate causing the issue you describe. Any bending of a circuit board is a big no no.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
You didn't actually help or answer my question though, you just repeated what I wrote in a way.
tarafından
Yorum Ekle
Yanıtını ekle
Kayl Snow sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 192
