Ana içeriğe geç
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
236 Soru Tümünü görüntüle
iPhone keeps turning on and off - Alcohol might help?
Hi all!
I have an iPhone that was dropped into water last week.
A few days ago it started turning on and off over and over again.
So I went to an authorized repair shop and they told me, that water came into the device and a little bit of rust is already visible.
Now to me question: Is there a chance, that the phone might exit that boot loop if the motherboard where cleaned within an ultrasonic cleaner and alcohol?
I saw some comments in another thread claiming they successfully repaired their phones with isopropyl alcohol:
Repairing iPhone Liquid Damage
Thank you already for your answers!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
@henerii the alcohol does not fix it, it is the cleaning that can help. Ultimately, this is what must be done to get a proper evaluation of what might actually have failed :-)
In your situation it will depends on what/where is rusted or corroded. Post an image of that with your question as well. It may narrow it down.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi
This absolutely could work(no guarantees though)
If you do go ahead with this make sure to remove the stickers and shields on the board
Also it turning on and off can be caused by a bad battery
Battery’s are one of the first things to fail after water damage so after cleaning a new battery might helps
Hopefully this helps
Any questions please ask
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If you remove the screen and only unplug the proximity sensor the phone may turn on. It’s pretty common for the prox to go out and cause a boot loop, if it was exposed to water. It’s worth a shot if you are just trying to access your data. Top speaker and some other things will no longer work but you can still backup 👍
Puan 0
Yorum Ekle
Yanıtını ekle
Henri Jäger sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 113
