Ana içeriğe geç
The Samsung Blackjack is an AT&T smart phone with 3G capabilities that runs on the Windows Mobile 5.0 OS.
What do I need to buy if it won't turn on?
My old BlackJack won't turn on, I'm willing to find parts to replace but I'm not sure what I would need to get.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
Hi,
Does it indicate that it is charging when you connect a compatible charger to it or connect it to a computer?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Cameryn,
First off, what's the history of this device? I'm going on the assumption that it's been sitting in a box for a few years and now you've pulled it out, dusted it off and are trying to get it to come to life. Is that close, or is there more to the story? Let us know, as that can affect how we go about figuring out how to bring it up.
So with that as the starting point, the first place to start is with the battery. All batteries have limited lifetimes and long periods of sitting discharged can kill them quite effectively. So a new battery would be my first purchase. Next, you'll want to try and verify the charger. That's going to be a bit of a pain, since it uses a 20-pin proprietary pinout on the charging port, so it might not be easy to figure out if it's working or not. You might try and locate a pinout for that connector and see if you can measure the voltage on the power and ground pins if you can figure out which ones they are. The charger itself should state what the output voltage is, so at least you'll know what you're looking for.
I'd say start there and let us know what you find then we can figure out what the next steps are once we're reasonably confident it's got power.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Check the Battery, most likely, this is exactly the problem
Puan 0
Yorum Ekle
Yanıtını ekle
Cameryn Cazan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 251
