Hi @dishproblem
Assuming that the arms rotate easily when you spin them by hand there must be a problem with the wash pump.
It is the pressure of the water being pumped through the arms that causes them to rotate.
It could be also a diverter problem. The diverter directs the water flow between the wash motor and the drain pump at the appropriate times in the cycle.
Here's the tech sheet for the dishwasher.
Run the diagnostics and check if any error codes show.
If there is a problem with the wash motor an F4 E3 code should show. If it is a diverter problem there will be F9 E? error code (could be E1, E2, E3 or E5).
The parts list doesn't show the diverter as a separate part so perhaps it is part of the wash motor.
If you find the problem search online using the part number only to find suppliers that suit you best. If the wash pump motor is the problem then the part # W11521435 is no longer valid as it isn't made anymore (unless you find a refurbished one online). If no good search for W11612326 as this seems to be a equivalent replacement.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
0
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
Hi @dishproblem
What is the model number of the dishwasher?
Can you hear if the wash pump is operating when the dishwasher is turned on or it is only "buzzing" as if trying to rotate?
jayeff tarafından
WDT540HAMZ
The water is pumped in, it drains fine, it seems to run a whole cycle without arm movement/water going through arms.
Deidre tarafından
