Why doesn't my furby finish sentences?
I have a 2005 furby which when it arrived it spoke perfectly and now when it speaks it doesn't finish the sentences, how does it get stuck and whistles :( ¿What can I do?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Since your 2005 furby used to work fine, but now cuts off mid-sentence, the connection has a problem. Sometimes the battery compartment/cover crack and break over time, since you have to manually screw it in. You can always buy a new replacement cover online. Like this one: https://www.etsy.com/listing/1209305021/...
So I would check to see if all the battery terminals are making a connection. Check for corrosion, if the batteries corroded recently, it could be the problem, and you may have to clean it. You can also reset these Furbys, hold down the tongue of the furby, and turn them off and on, this could help fix the problem. Here is a video showing how: https://youtu.be/SjOP8gH6mCE
I am only concerned about it getting stuck and whistling, the whistling could be the motor humming and the gears could be stuck, meaning you'd have to take the furby apart to lubricate the gears, when it gets stuck try moving the ears, beak, and feet. This may move some of the gears internally and get the furby to move again. If you need any further help you can always contact me at Oliviarepairs@gmail.com or my Youtube channel: Olivia Furby Repairs
I hope this helps, Thanks!
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 64
2 Yorum
anthony estay let's see if the resident repair guru Olivia's Furby Repairs https://www.ifixit.com/User/3500511/Oliv... sees this question. I am certain that your Furby can be helped :-)
oldturkey03 tarafından
@oldturkey03 I am here :)
Olivia's Furby Repairs tarafından
