Ana içeriğe geç
Repair guides and support for your Samsung TV.
2491 Soru Tümünü görüntüle
TV not responding once on and won't turn off
I have a Samsung UN48H5500AFXZA.
It recently stopped working and I tried replacing the main board without success.
Original main board - it will turn on via remote or button. However, once on it is unresponsive. Backlight is lit up but trying to do anything (changing source, channel, volume, etc.) does nothing except the light on corner of TV will flash showing its receiving signal from remote but nothing happens.  The TV will also not even power off via remote or button.  If on, it will only turn off by unplugging.
New main board - when using remote or button to turn on, the screen lights up 1 second and then it turns itself off.  It won't stay on longer than that brief flash of 1 or 0.5 seconds.
Any ideas?
Thanks
DW
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@dw57978 first you need to rule out your inputs as error source. Remove all of them (especially if you have some sort of cable box, sat box etc.). Unplug your TV and unplug all input sources. Hold down the power button for 30-60 sec. Then reconnect one input source (preferably local, something like Game console, DVD/BR player). and make sure you use a known-well HDMI cable, if that's how you connect. Lastly reconnect the TV and try to turn it on. See if that changes anything.
Next remove the back cover from your TV. Let's see if your power supply works. Disconnect the main board from the power board and connect the AC cable. Something like done in this video up to 0:30.
If your back lights come on you know your power supply is good. Also see if the start-up behaviour has changed. Next you need to see if it is a T-con board error. Reconnect what you disconnected first. Then unplug the T-con board (small green boar that has one flat ribbon cable going to it from the main board and two going to the panel. Disconnect the one flat ribbon cable from the main board. Behaviour changed?
Not sure why your main boards have such a different startup but we assume your new one as working order. Last but definitely not least, measure the voltages on the power board connector where the cable to the main board connects to. Let us know what voltages you get.
It will help if cour can post some pictures of what the boards and interconnect cables look like. Take one picture of all of that and then a picture of each individual board. Pst those with your QUESTION. Edit it and use this guide Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
DW57978 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 27
