Ana içeriğe geç
How to pry power supply connector from logic board
I'm trying to install a new power supply I just received from you. I've tried everything according to your instructional video but I cannot pry the connector away from the logic board. I've gone so far as to remove the power supply with the connector attached so I could get under the connector but it's no go. Can you help?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Jsoter,
The connector is stuck in there pretty darn tight. We've found that the best method for disconnecting it has been to depress the connector lock while using a heavy duty spudger, or other gentle but strong prying tool, to firmly jostle either side of the connector until it comes free. It usually takes a few tries at each side, but as long as you are depressing the connector lock at the same time, it should come free with some persistence.
Hope this helps! Let us know how it goes.
Heavy-Duty Spudger Görseli
Ürün
Heavy-Duty Spudger
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Thanks. I finally got it.
tarafından
Right on; glad it worked!
tarafından
Yorum Ekle
Yanıtını ekle
jsoter sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,009
