Ana içeriğe geç
Repair guides and support for coffee makers by Keurig including the K-Cup systems.
464 Soru Tümünü görüntüle
accidentally Plugged my K-supreme on 220v outlet
Hello I accidentally plugged my Keurig machine to 220v outlet, I opened it and saw MOV and 10ohms resistor beside it was burned. I ordered replacement part (MOV 14D241k & 10ohms) now when I re-solder it and tested it the resistor (10ohms) keeps on exploding, I Got 9pcs left. can anyone can help me what should I check? I only know basic knowledge on electronics.
Untouched Board (Right after disassembly)
Update (02/07/2023)
those black spots on the back caused my a resistor blew mounted on the back of the board.
when I test the newly attached components I only plugged the 3 terminals bellow BLK,BLK, WHTE
and the 10ohm resistor keeps on blowing
Update (02/22/2023)
Is this board compatible to the machine particularly on the display Board? It has different part number but it is for Keurig k supreme.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Super User, Start by taking som good quality and up close pictures (use good lighting, high F-stop, long shutter speed and a tripod to get the best pictures), of the board(s) in your machine, both sides. Then update your question and add those images. Adding images to existing questions, this will let us see what you see
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Super User, It’s not really possible to tell much from the images you’ve added, unfortunately.
I’m hoping you took the board(s?) out and did a repair? It’s much, much easier if you take the board out, to get a good picture that tells us something. Pictures at angles and in weird positions make it hard to determine a lot of different things. The best is a board laid flat on an even surface, then image taken from directly above using a tripod, long shutter speed, high F-stop (aperture) and a LOT of lighting.
You say that you replaced the MOV and the power resistor? Could you take close up pictures (as explained above) of the repair? Also, do a very thorough inspection of the board and components, to check for damage or “suspicious things”.
If the MOV and a power resistor blew, then it appears there was no fuse or protection circuitry built in, and it tried pumping the full 220V into the 110V board (bad idea!).
What is the exact model number of your Keurig? This will help in possibly finding a service manual and / or schematics.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Comments:
Do you have some Diagram of K921?
tarafından
Super User (SuperUser), Keurig K921? I can’t seem to find any reference to such a model online..?
tarafından
@Super User (SuperUser) what is that jumper on the back of the board for? What happened there?
tarafından
Copper plate chipped off just reconnected it.
tarafından
Yorum Ekle
Yanıtını ekle
Super User (SuperUser) sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 85
