Ana içeriğe geç
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 Soru Tümünü görüntüle
Will it run without the battery?
The battery is dead. It powers down within a minute or two after I unplug it. I'm concerned that the battery could develop issues, since it's dead and under charge 100% of the time.
Can I just pull the battery from it and reassemble it? I only use it plugged in at the moment. I realize it sounds weird, but it's an old iPad. (It's in the 'old folks home' part of its life) I really don't see using it seriously as a battery powered iPad depending on the battery, so why replace it. I just want it to be 'safe' if the battery decides to swell or overrun. In other words, I can't afford to replace it, and see no need to replace the battery, but would like to keep it working. Long question, I know...
Thanks...
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
No, it needs the battery. Easiest way is just to order a cheap battery to replace the one in it since you plan on opening anyway.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
100% can confirm. These will not boot all the way most of the time without an installed battery.
tarafından
Yorum Ekle
Yanıtını ekle
RobCow sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 55
Her zaman: 546
