How to replace bad charging ports
The charging ports do not charge battery any more. Impossible to find anyone who will work on it. Any information, tips, etc are greatly appreciated.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi Cynthia!
So its fairly easy to access/replace the charging port. The laptop uses T5 Screws. I found a teardown video that should guide you (at 5:20 in the video is when he starts removing the charging port)
This is what the part will look like in the computer. If you can send me the model number, I can find an exact part for you!
Bu yanıt yardımcı oldu mu?
Well I will suggest you to change the old port with the new one and if your not able to do it by your self then you can take help of any technician who has the knowledge of replacing the part and change the port without damage your device.
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 66
Her zaman: 489
