I have a 2008 Maxima 3.5 that won't crank.
I just got the car last week and they had almost no power at all, for example if I would hold the gas pedal down a quarter of the way it had more power than all the way down. When I shut it off it took a lot of effort to turn back on or I would have to get a jump start to turn it back on. I thought it would be my crankshaft positioning sensor but I just got a new one from the junkyard and it's still not working. Somebody please help me this is my only source of transportation.
Bu iyi bir soru mu?
If the engine runs, it's not likely to be a crank sensor problem. A blocked (disintegrating internally) catalytic converter (or several) can choke off exhaust flow as the equivalent of engine constipation. A simple test would be removing the upstream O2 sensor(s) on the exhaust manifold for an alternate exhaust path. If the engine starts up (loud) and a brief drive around the block reveals renewed power, the catcon(s) are damaged. Another issue may be a worn out fuel pump requiring testing with a fuel pressure gauge connected to a fuel rail test valve. You'll need to know fuel pressure specs with either ignition on (immediately) or with engine idling).
F Dryer tarafından
