Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
Where to go next with my repair.
I have been teaching myself how to restore the Fat PS3. This is my first try in repairing this type of console.
Recently, I have taken apart a reverse compatible CECHB01. Before my repair attempt, i plugged power and HDMI in, pressed the power button and all that would happen is the Red light would go green and then back to flashing Red (No yellow or blue.) So i cleaned all the dust out, hit the cpu and gpu lids with a heat gun for 30 seconds each on high, put fresh mx4 on the cpu and gpu lid and closed it back up enough to test. It now turns on!! However, the fan ramps up high after 10 minutes of playing a game (dark souls) but is fine when not playing a game. (Maybe bad GPU?)
I don't want to burn this console out, so it goes back on the shelf for now. I do not know if this is normal due to lack of experience.
What should be my next move? Try de lidding the cpu and gpu to thermal paste under those before i will get adequate cooling for each? Im feeling the the NEC tolkens are fine if it is running right now. Is the fan supposed to ramp up so fast? Is it fine and i just do not know it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@lancematthew "Im feeling the the NEC tolkens are fine if it is running right now." don't go down that rabbit hole. That myth has long been debunked and there should be absolutely no issues with those.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I don't usually do PS3s, but the ones that I have, that still have their IHSs intact, I've used the eraser trick to good effect. https://www.psx-place.com/threads/tutori...
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Ill check this out and give it a try! Thanks!!
tarafından
Yorum Ekle
You should have replaced the thermal paste when you had it open. Would help in cooling the system.
Puan 1
1 Yorum:
I did on the outside of the cpu/gpu lids. I didnt de lid them and do the underside.
tarafından
Yorum Ekle
Yanıtını ekle
Lance Matthew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 158
