Ana içeriğe geç
Bajaj Discover, Bajaj Auto tarafından üretilen bir motosiklet markasıdır. Şu anda Discover'ın dört farklı modeli bulunmaktadır: Discover 100 DTS-Si, Discover 125 DTS-i, Discover 125ST ve Discover 150 DTS-i.
It can't start
My motor bike is not starting
Bu iyi bir soru mu?
Puan 18
13 Yorum
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
tarafından
My motor cycle not start
tarafından
Bettry charging
Palag problem
Indicetar chlu
tarafından
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
tarafından
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
tarafından
8 tane daha yorum göster
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
Bu yanıt yardımcı oldu mu?
Puan 7
Yorum Ekle
Try kick start maybe your battery is worn out
Puan 3
Yorum Ekle
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
Puan 0
Yorum Ekle
Start with the basics 👍
  • Check battery (most common, does it crank?)
  • Fuel on + not empty
  • Kill switch off
  • Listen: no crank = battery/starter, cranks but no start = fuel/spark issue
If it’s been sitting, fuel or plugs are usually the culprit.
Puan 0
Yorum Ekle
Yanıtını ekle
Geoffrey Ouko sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 27
Son 30 gün: 196
Her zaman: 8,242
