Ana içeriğe geç
Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
20 Soru Tümünü görüntüle
iPhone 13 mini dropped and only Wifi/Bluetooth aren't working
It was dropped and the screen suffered damage. After that everything still works except wifi and bluetooth which are not recognised.
What exactly might have happened at board level?
I guess something has moved on the board.
If I use a heat gun on the board, is it possible to solve the problem, or is the board-level repair going to be more complicated?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If Wi-Fi is greyed out in the settings app it would point to a board problem not the antenna. The most common cause for this is cracked or torn pads between the interposer board and the top board after a drop. To do this repair will require microsoldering skills and the correct equipment.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
no, it will not help, you need to replace the wifi/bluetooth antenna, the board has nothing to do with it
https://www.mobiledefenders.com/wifi-and...
note that you need soldering skills to replace the antenna that is connected to the board, but you can try to replace the antenna that is held to the board by a flex cord to see if that will fix it. if you don't have any soldering skills, and if that doesn't work you may need to take it to a shop.
https://www.youtube.com/watch?v=P-vTM-QQ...
Puan 0
Yorum Ekle
So finally what happend? Did you resolved this problem? If yes, could you please share how or what was the solution to fix.
I have the exact same problem.
IMEI, WiFi address and Bluetooth address present
somtimes find Wifi but it seems signal very low.
Puan 0
Yorum Ekle
Yanıtını ekle
Alex222 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 1,520
