Ana içeriğe geç
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
The headphone jack isn't working properly
The headphone jack only allows the right earphone to work. I can jiggle the connector and it breaks up. How do I fix it? It doesn't matter if I change to different headphones... it still does the same thing.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check to see if you have broken a tip off any of your headsets. It may be in the iPod and preventing full contact.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
This means that the headphone jack is becoming faulty and needs to be replaced. Simply locate the size of your iPod video and replace the headphone jack/hold switch. Very easy to do.
Puan 0
1 Yorum:
What's the reason for the downvote? Sure, you should check the headphones out first. But this is a solid response.
tarafından
Yorum Ekle
Yanıtını ekle
SuzV sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,051
