My iPhone Randomly restarts
this is what it is saying
Bu iyi bir soru mu?
Hi Jefferson,
Chances are good you've got an issue with the charge port assembly. PRS0 is a sensor located on that flex cable and the kernel panic you're seeing is exactly what happens when the processor can't communicate with that sensor. You can read more about it on @flannelist's excellent Wiki article on kernel panics.
Generally the fix for this is to replace the lightning port assembly. Note that this is a fairly difficult repair, mainly due to the amount of parts you have to remove to get to the flex cable. iFixit has a video guide available here.
iPhone 11 Lightning Connector Assembly Replacement - iFixit Repair Guide
If you prefer written step-by-step directions, you can find a pretty good guide over on the French SOSav site. The automatic translation works fairly well as long as you understand that the "flex cable" translation comes across as "tablecloth" and batteries show up as "drums".
Charge connector iPhone 11 repair - Free guide - SOSav
You can get a replacement assembly right here on iFixit; note that the inside of the port is visible so you'll want to buy one that matches the color of your phone. You can also find the part on most of the big retail sites like Amazon, eBay and AliExpress.
Be sure and pick up a sheet of precut adhesive for the screen to seal it back up when you're done; to be honest I usually buy a couple when I do a screen just because they're easy to mess up and you don't want to have to wait to reorder before you put the phone back together if that happens.
Good luck; let us know how it goes!
Bu yanıt yardımcı oldu mu?
I own a repair shop so i have reasonable experience in repairing iPhones i never opened an 11 so i will watch the guide a few times… Thanks for confirming its the charging port flex i placed an order for one a few hours ago from ifix when i receive it and swap it i will give you an update thanks alot really appreciate it;)
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 65
