Ana içeriğe geç
The HP ProBook 450 G3 was released in 2015 and has the model number T3L10UT#ABA. It has a 15.6 inch 1080p display.
My hp probook won't turn on an issue with power button.
My HP ProBook won't turn on an issue with power button, I need to take the hard drive and connect it to different laptop, I have never did that before and I need help or instruction from 0 to the last step please to make the laptop functional and operation with the same data as in the current Hard Drive.
Many thanks in advance.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If I understand you correctly you want to take out your hard drive and connect it to another computer to read your data.
To remove hard drive
Then you will an external USB connector for the drive.
For example - select your dealer of choice.
Plug it in to another computer and transfer your data.
If you are asking if you can boot the drive on another computer the answer is no as it is different hardware and Windows will object.
If you want to try and fix the power button on your HP Probook 450 G3 please give us more information.
Does that help?
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Emad A Ali sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 129
