Ana içeriğe geç
2.3L 4cyl or 3.0L V6, 6th Generation
425 Soru Tümünü görüntüle
adjustment of headlights on 2001 Honda Accord EX
I just replaced the headlamps on my Honda Accord Ex. How do you adjust the lights? The left side appears to be in pretty good focus but the right side is great if you are looking for owls in the tree tops! I would appreciate someone sending me an instruction guide since I have no manual for this car.
Thanks! John
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
John, some information about your job from here" Park the Accord in front of a blank solid surface like a wall or garage door. Turn on the vehicle’s headlights and use a piece of tape to mark the center of each headlight beam on the wall. This will be the reference point for the headlights. Move the Accord 25 feet away from the wall. Pop open the hood and insert the Phillips screwdriver into one of the vertical adjusters under the hood. The vertical adjuster is a round cylinder situated behind each headlight, close to the radiator support. Inside each vertical adjuster is an adjustment screw used to raise or lower the headlights.
Turn on the headlights. The center of the headlight beams needs to be 2 inches above the spot marked on the wall. Turn the screw clockwise to lower the beams and counterclockwise to raise them. Once the center of the beam is in the correct position, close the hood." Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 5
4 Yorum:
Thanks again, this will help me greatly!
tarafından
Thank you for accepting my answer. Good luck to you.
tarafından
It should actually be 2 inches BELOW the bulb height at 25 ft. so the beam is aiming slightly down, not up.
tarafından
Thank you so much for all the information and instructions. Good bless America. John Yang.
tarafından
Yorum Ekle
Starting from the tape how far from the wall does the car need to be? ( before moving it back 25 ft.? )
Puan 0
1 Yorum:
Flat road , flat wall , 1 foot from wall,mark w/tape both lamp beam center beams(as shown on wall)
Move vehicle back 25 feet
Adjust center of beams to
Dead center on tape , too -
2 inches below (find your best night driving adjustment ). However you will not be distracting on coming traffic
tarafından
Yorum Ekle
Yanıtını ekle
John sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 22,082
