OPTIARC DVD RW AD-5630A Alternatives..!
My 24" 2.8Ghz Intel iMac Core 2 Duo Extreme's OPTIARC DVD RW AD-5630A has failed.
On checking various forums it's symptoms are concurrent with many other users.
I now need to replace it, though would be looking for an alternative, like for instance the 12.7 mm PATA 8x Pioneer SuperDrive........Would this be compatible?
I am obviously looking for a more reliable drive, so any advice would be great..
Bu iyi bir soru mu?
1 Yorum
I successfully fitted a new super-drive, which although buying the Sony OPTIARC DVD RW AD-5630A replacement, I actually ended up with the Panasonic (MATSHITADVD-RAM UJ-846S) drive..!!........... I got my drive from here: http://www.ecrater.co.uk/p/11642957/repl...
I did have to remove the two small locating lugs on the front of the caddy and the other thing I have found is that using this drive with the caddy for the Sony Optiarc, it doesn't situate the drive closer enough to the outer edge of the imac, which does cause problems with activating the drive so it pulls the CD/DVD into the machine. I now have to just slightly touch the edge of the inserted CD/DVD with a credit-card to get the drive to activate..!!
MikeJarvis tarafından
