Ana içeriğe geç
The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
Watch is charging but won't turn on after water damage repair.
I took apart my Galaxy Watch Active2, disconnected the battery and cleaned the inside with isopropyl alcohol after it was stuck in a boot loop from what I assume was water damage. After putting it back together and putting it on the charger, it shows that it's charging but won't turn on when I press and hold the power button.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@jackhardacre just because it says it's charging it might not be. Replacing a battery after water damage is almost always a must do. Of course, double check your work too and make sure everything is connected as should. Ultimately, it could also originate from the water damage having created a short circuit somewhere on the board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Jack Hardacre sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 305
