Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
369 Soru Tümünü görüntüle
Why is the replacement battery not charging
The battery was recently replaced due to a problem that occurred when it was in use for a lengthy period of time. The bottom of the notebook became unusually hot swelling up the battery and making it impossible to close the casing. Therefore, i replaced the damaged battery with a new one, however, it does not charge at all. I'd also like to add that the notebook shuts off every time the power cord is not plugged in and the green indicator light lights up when it is plugged in.
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have you tried resetting the SMC first?
Failing that, you may consider rechecking the battery.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorumlar:
Repair your disk permissions first in disk utility. They try resetting the SMC like Stefano suggested. If that doesn't work, shut down your computer and physically disconnect and reconnect the battery cable from the logic board.
tarafından
Yorum Ekle
Yanıtını ekle
Yuri Sarnoff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 4,223
