Ana içeriğe geç
Onkyo TX-800, 1989 yılında piyasaya sürülen ve 2002 yılında üretimi durdurulan bir solid state (yarı iletken) alıcıdır.
Why won't the left main speakers work?
I bought new speakers for my Onkyo receiver. I've connected the speakers with speaker wire to the main speakers outlet in the back of the receiver. Only the right side speakers produce sound. To check if I'd made a faulty connection, I then switched each around, and the same result occurred; the right side works, the left does not.
Bu iyi bir soru mu?
Puan -1
3 Yorum
Laura, don't mean to insult you, but did you check the balance settings? Any difference?
tarafından
Yes, I'd already looked into the balance settings.
Looking at the manual, t appears as though this is over-my-head. I will look into finding professional repair. Thank you!
tarafından
Laura, thank you for accepting my answer. Best of luck to you....:)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
if you have no difference on your balance settings, I would go ahead and take a look at the AN7470 Stereo decoder as well as the IC NJM45580-x. Of course you also should look for any burned out components on the logic board. Download the service manual for your Onkyo from here. It does have the circuit diagram as well as a parts list that will help you with it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Laura sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 4,055
