Model A1297 / 2.66, 2.8, 2.93, or 3.06 GHz Core 2 Duo processor
1153 Soru Tümünü görüntüle
How to tell if it working correctly
I have MAcBook Pro 17 and I had to send it back about a month I got it and they had to replace the key board, logic board and track pad and the case. The track pad doesn't respond all the time when you double click on it nothing happens. How can I tell if this machine is working right?
Is there a diagnostic program I could get to see if it is working right.
Puan 0
Add a comment
Android Tamir Setleri
Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
Hemen Alışveriş Yapın
1 Cevap
Chosen Solution
Is it only one double clicks, or do single clicks not register all the time either?
There is a setting in System Preferences -> Trackpad that allows you to adjust your double click speed. Try turning that down and see if they register more often.
Puan 0
Add a comment
Add your answer
Michael will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 297
