iPhone shows apple sign then loading circle
Ok so i did a glass replacenent and everything was fine exept the touch on the right side of the screen was not working very good so i removed the glass/lcd out to reconnect the cables and now when it turns on it shows the apple sign then after about 4 or 5 minutes it only shows the little loading circle. Need help this is my Managers phone....
Bu iyi bir soru mu?
4 Yorum
Did you back up the data on the phone? A restore may be necessary.
Phillip Takahashi tarafından
Yes i did all that ... Held the home button then plug in, then the power button thing and it restored then just went back to charging sign the when it turned back on it still does the same thing
Daniel pecina tarafından
Is it somthing i did while changing the glass??
I think i messed it up .... I chipped a little peice of the little switch connecter off bout the with of a razor any way to fix that.... It happond during second removel to check the connection...
