Ana içeriğe geç
will this screen fit?
will IF150-001 fit on an iBook g4 1064 mhz machine?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That's the complete assembly from a G3 iBook which won't fit. The LCD inside it 'should fit', but those early translucent G3 iBooks used an IBM screen which isn't as bright as the Samsungs used in the later G3 & G4 iBooks.
You want either IF183-026 which is the complete assembly, or IF150-052 which is just the LCD panel. Despite what instincts may tell you, fitting just the LCD panel, is a lot easier than replacing the whole top assembly.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
The 12" LCD panel itself can be swapped between these Mac models:
- iBook G3 12"
- iBook G4 12"
- PowerBook G4 12"
Display assembly (plastics and cables) are often different and may not fit.
Puan 1
Yorum Ekle
Yanıtını ekle
robm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 895
